Hi folks. I have lurked around here for a couple of years reading all that I could about CNCs. At first I thought I would build one and after watching so many people spend so much time and money on their first machines with mixed results I decided to search for a new machine for my needs.
What I wanted:
1. At least 24" by 36" by 7" work envelope
2. Extremely rigid for superior finish quality
3. Must have a spindle for precision (and quiet)
4. Ease of use
I looked at all the machines I could. I had a friend that had a another machine that I prototyped some work with but the finish quality was not that great and it could not perform cuts into solid wood and produce smooth, chatter free edges. Even at very slow feed rates the bits chattered due to the insufficient gantry supports.
Then I visted Carl Bruce in Bremerton, WA. I tested his machine and it was light years ahead of anything else I tested. The reason I went with Carl are: overbuilt design, came with a spindle, local business, and excellent support and reputation, and of all the cuts were finish quality right off the machine.
Here are the specs:
25" x 36" x 7.5" work area
Dual x drives for ultra rigid gantry
Precision ballscrews and hiwin linear rails and bearings on all axis
Built with 1/2 and 3/4 6061 aluminum
Cast aluminum milled Mic-6 deck drilled and tapped for hold down
400ipm cut speeds and rapids,
Water cooled 2.2 kw[3hp] spindle,VFD,and cooling system.
Price: $6600
Carl Bruce: [email protected]
Here are some photos:
Cutting a Claro Walnut carved top:
Parallel finishing at 8-percent offset 0.03" from perimeter edge followed by a pencil tracing pass to clean up the edges.
This is the first cut I made. It took a couple swipes with 220grit to clean it up. Spiral machining cut at 8-percent stepover with a 0.50" spiral ball nose bit.
These cuts are being made at about 230ipm with a total cut time of 25 minutes. I pushed it to 300ipm for the first cut to see what it can do and it seemed to run fine but dropping it below 250ipm stopped some low end motor noise. It was really moving!~ My goal here is precision and finish quality, not speed. Still, this used to take me nearly 2 days by hand using a duplicarver and orbital sander to shape the top, and all manner of hand tools cutting and fitting braces. And the sanding time is negligible now.
This is my first week with the machine but I have been preparing. For the last 2 years I have been learning CAD and developing my 3D models in Rhino. And I have spent about 2 months with RhinoCAM simulating tool paths getting ready for the machine's arrival last week. I was able to cut a part immediately and have all of my singlecut carved top shapes done so far. The rest of this week and next I am going to develop my fixtures and machine code for guitar necks. That's where the real time savings is going to come.
Controller software is Dynomotion using the KFlop boards and drivers. USB connection is fast and no interruptions. I can run Rhino while the machine is running if I want to. I don't but I could. Great software. Easy to configure, and easy to operate. I have a background in programming so that probably helps.
I hope that this post helps anyone looking for a machine that will cut guitar parts with precision and quality. It's the best machine I have tried by a long shot. That's why I bought one.
~David
