586,798 active members*
3,226 visitors online*
Thread: cutoff tool
    Jul 2012
    cutoff tool
    i am having trouble with the cutoff insert being pushed out of the toolholder. i am running hose menders on a star sr-20rII. any help is appreciated?
    tool inserting problem
    I think you should check the draw bar assembly and the tool holder collet. You may try this
    tool is not inserted into spindle,problem in drawbar, disc spring or collet.
    May 2004
    4519
    During side turning or plunge cutting? Is material moving during cutoff? Is the tool mounted exactly on centerline or below centerline?
  1. Groove/Cutoff tool is p!ssing me off...
    By Japazo in forum MetalWork Discussion
    Last Post: 03-04-2012, 07:59 PM
  2. Cutoff tool
    By jroma1 in forum MetalWork Discussion
    Last Post: 08-15-2009, 02:43 PM
  3. work-shifting cutoff tool on a swiss starsr20
    By jeff88 in forum CNC Swiss Screw Machines
    Last Post: 02-13-2009, 03:37 AM
  4. Not sure what to get for cutoff
    By KyleH2 in forum Want To Buy...Need help!
    Last Post: 01-18-2009, 06:54 PM
  5. Mach running a cnc cutoff saw
    By cut more in forum Machines running Mach Software
    Last Post: 11-06-2007, 07:21 PM
