Hi, I have an OSP 200L control ( LB 3000 EX My) which UPS battery is expired and alarming, replaced the battery but cannot open the Battery Data screen to update the new battery, any idea how to enable that page? Thank you
Probably need the battery replacement disk from okuma. Not 100% sure on a 200. One more way for Okuma to screw its customers.
It should be in one of the parameter pages. If you dont see it listed you might not have the box checked to display the correct parameter screen or the display all box checked. I'm not in front of the machine so I can't give you step by step instructions, but this should get you close. Press parameter button, push arrow to see the next set of tabs. There should be a tab that says display or display options. You should see all the possible parameter screens and you can select the ones you want to see. There is also a display all box.
Don't forget to change the pc's bios battery when you change the ups batt.
Thank you Edster and UNderthetire for your responses, managed to get to page, missed the Edit enable switch.
