Looking for a quote to produce the following item in Aluminium or some form of hard plastic.
Coming from a wood working background, I'm not too clued up on metal or new hard plastics and economical dimensions for best costing so would be gladly guided by someone in the know. For instance the 80mm is not exact and could be slightly smaller.
The 8mm hole goes right the way through.
It will carry a load of no more than 2kg.
I would initially require 2no but this may end up being more (without trying to dangle a carrot)
Thanks and if you need any further information please don't hesitate to ask.
