587,157 active members*
3,229 visitors online*
Page 19 of 19 9171819
Results 361 to 375 of 375
  1. #361
    Jul 2004
    1424
    Re: Cheap TTS style collet chucks
    20% and free shipping from Enco if you order before tomorrow night (6/30). They have some jacob's chucks already on sale, if you pick the right ones., you can get a really good deal.
    Coupons: 20JUNVIP and JUNSHIP
    EDIT: my synapses were firing at random there. I just bought a couple of Jacob's drill chucks (they were on sale + % off + free ship made them a steal), but of course the poster above is talking about TTS ER20 chucks, when Enco doesn't have. You could buy ER20 collets from them, however.
  2. #362
    Jun 2007
    3891
    Quote Originally Posted by tmarks11 View Post
    I must have missed that story... looked back at your threads, but didn't see it. Care to elaborate?
    no story. just flames and melty plastic. hehe. spark from cutting steel hit some wood dust I was too lazy to vacuum up first and lit up. less than 30 seconds of fire, but it got behind the column and melted the wiring from the cabinet to the motors. been too bust with my router to fix it for now. It needed a new spindle cartridge and motor anyway so im looking for bt30 maybe.
  3. #363
    Jun 2014
    1780
    Quote Originally Posted by diyengineer View Post
    Ahh that sucks! :/ Only thing in wish tormach did better on the setscrew holders would be to standardize the Allen head screw they use! Make one Allen wrench for all of the damn things! Haha
    A trip to the hardware store fixed mine, I just replaced them all with new ones, they were much better quality and the standard wrenchs fit the various sizes involved.
    mike sr
  4. #364
    Sep 2009
    15
    Can someone please tell me what thread is used in the shank of the TTS and how deep it is?
    If not threaded, diameter and depth of the hole?
    thanks
  5. #365
    Apr 2013
    1788
    I have real Tormach ER and Weldon shank style TTS holders plus some ER ones from Darkon and none have threading inside the shanks. The diameter of the shank OD is 0.750. See http://www.cnczone.com/forums/attach...1&d=1168031791 for a drawing of the screw type holders.
  6. #366
    7063
    Quote Originally Posted by A_hobbyguy View Post
    thanks
    There are no threads in the shank of any TTS holder, and the bore size is different for different holders. Some have thru-bores as large as 1/2", some have no thru-bore at all.
    Ray L.
  7. #367
    Sep 2009
    15
    Thanks for the pointer to the drawing, kstrauss.
    Also thanks SCzEngrgGroup for clarifying the mystery of the shankhole (sounds like something nasty you'd call someone, doesn't it?)
    Anyone know the diameter of the toolchanger disk, as well as the ID's and depth of the collet clearance well?
  8. #368
    Dec 2016
    37
    I Just received some collet chucks from YSTools. Very happy. All surfaces nicely ground.
    Clocked em up on the shank of a endmill and they are more accurate then my Tormach tts holders.
    Just wondering if anyone has tried YSTools 50mm Face End Mill Cutter?
  9. #369
    Apr 2013
    1788
    Could you please provide a link to your place of purchase?
  10. #370
    Oct 2010
    670
    It's most likely these guys. I think I'm going to pull the trigger on a set of these today. I need to see if they sell ER16 sets as well.
    wholesales 10pcs C3/4 ER20 1.38 Straight collet chuck holder CNC Milling Lathe | eBay
    The Body Armor Dude - Andrew
  11. #371
    Dec 2016
    37
    TTS style collet Chuck's:
    http://m.ebay.com/itm/wholesales-10pcs-C3-4-ER20-1-38-Straight-collet-chuck-holder-CNC-Milling-Lathe-/281722204251?nav=SEARCH
    But was wondering if anyone had tried this?
    http://m.ebay.com/itm/New-C3-4-Shank-50mm-face-end-mill-cutter-400R-50-22-10pcs-APMT1604carbide-insert-/281250767446?nav=SEARCH
    It has a longer shank so I'm not sure if this would be a problem. At work so can't check.
  12. #372
    Dec 2016
    37
    On a second look I don't think it would work. The surface that sits against the spindle is not ground and looks too small
  13. #373
    Apr 2013
    1788
    I doubt that it is too small since it appears to be about the same diameter as the body of the 50mm face mill and these are typically 1.75 or larger at the base. You could always add one of the TTS adapter rings from Tormach and cut off the too-long shank.
  14. #374
    Dec 2016
    37
    Good point.
    I did think of the adapter ring. Problem is I live in NZ this all adds up to expensive shipping costs for an Unknown/tested tool.
    The ring would also take up some of the longer shank so it may not require cutting.
    YSTool 50mm Face End Mill including 10 carbide inserts $65 + Tormach Adapter ring $17.50 = $82.50 USD plus shipping cost from both companies.
    Tormach TTS 2" Shear-Hog (50mm) including 2 Carbide Inserts $395 plus shipping
    Or you could compare it against the Tormach 38mm Face Mill with TTS arbor and 10 Carbide inserts for $316.41
  15. #375
    Jan 2007
    16
    New 3/4 FMB22 arbor +50mm face mill cutter and 10pcs carbide inserts CNC Milling | eBay
    Quote Originally Posted by Labern View Post
    I bought one of these about a year ago from YS Tool and it has worked well:
  1. 5c Scroll Type Collet Chucks?
    By Chuck_jaws in forum Uncategorised MetalWorking Machines
    Last Post: 08-26-2011, 12:45 AM
  2. collet chucks - lathe
    By ace of spades in forum Want To Buy...Need help!
    Last Post: 11-10-2010, 01:45 PM
  3. collet chucks
    By cordeirot in forum Uncategorised MetalWorking Machines
    Last Post: 05-04-2010, 05:52 PM
