586,171 active members*
3,163 visitors online*
Results 1 to 3 of 3
    Jan 2004
    539
    1000 psi prime issues
    Made the mistake of firing up the tsc with the drain on the sock filter housing open. So It sucked up a bunch of air.
    Now cant get it to prime back up.
    Sock filter housing filled to the top.
    Manually taken every hose off and filled each line.
    Oxnard told me to crack the high pressure line while it is trying to prime..still nothing. :tired:
    Need a trick or two to make the magic happen :cheers:
    Gary
    When mine loses prime, I turn on the external coolant and the 1000 psi re-primes and all is go to go..
    Jan 2004
    539
    Thanks for reply. After two long days it turns out the small pressure line that is supposed to be plumbed into the standard coolant...was just laying in the coolant tank. :nono:
    I figured it out when I found the install instructions in the spare filter box. :idea:
    Primes right up now.
    Gary
  1. 1000 xp3
    By splash in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2011, 11:32 PM
  2. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
  3. TMC 1000
    By Tracey Point in forum CNC Tooling
    Last Post: 02-23-2011, 06:42 PM
  4. TMC-1000
    By mdeangelo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-23-2011, 06:37 PM
  5. SLA7051 Board - Ready for Prime time ?
    By pminmo in forum Open Source Controller Boards
    Last Post: 11-14-2005, 10:25 AM
