587,056 active members*
3,501 visitors online*
    May 2012
    tool changer stuck vmc 850
    the alarm is 1066 atc not in zero position, the arm of the tool changer is stuck between the spindle and the carousel. Is there a m-code to try or do i have to remove it manually. Thanks alot
    automatic tool changer.
    You have to rotate the arm manually from motor by releasing the motor brake.
    you should try this
    Automatic Tool Changers and Tool magazines with characteristics
  1. Kit tool changer arm stuck in mid stroke
    By new2kit in forum Kitamura
    Last Post: 05-27-2019, 10:50 PM
  2. HAAS VF-4 sidemount tool changer stuck HELP
    By panaceabea in forum Haas Mills
    Last Post: 03-03-2009, 01:56 AM
  3. Tool Changer Arm Stuck
    By swartling in forum Haas Mills
    Last Post: 06-03-2008, 08:50 PM
  4. Tool Changer Stuck
    By cterrymachine in forum Fadal
    Last Post: 09-20-2007, 03:54 PM
  5. Tool changer stuck, help
    By ShortRunCNC in forum Daewoo/Doosan
    Last Post: 05-19-2007, 01:23 AM
