586,521 active members*
3,468 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 1/32 Endmill cutting aluminum?
    Aug 2005
    828
    I need to make a aluminum gear 1 1/2 diameter with 34 teeth. I found some 1/32 end mills on ebay, 2 and 4 flute. Wich will be better for this? This will but the BP retro to a real test.
    Endmill
    Dennis
    Apr 2003
    1873
    Dennis,
    That small the two flute would be best and as fast (RPM) as that BP will go
    Carbide is the way to go.
    Ken
    Aug 2005
    828
    What if I tape a dremel to the quill
    What feed rate and depth of cut will I need to use?
    Dennis
    Jun 2003
    1365
    Runnout, You'll typically find .01" runout in a dremel tool. My RTX had less but not much. we had to drill some .004" holes and we tried but it kept breaking the drills and only successfully drilled 1 hole.
    Jon
    2 flute for sure. The 4 flute wouldn't have enough clearence for the chips. I cut my gears with a 2 flute 1/32" endmill at 3500rpm with a .02 DOC at 2.5ipm.
    Proud owner of a Series II Bridgeport.
    Apr 2005
    29
    You should maybe look into WM Berg for a gear like this and then just mill it to size (unless this is a very irregular gear). I am doing this for a project I have and spent $20 on a gear and will just skin the 2 faces and be done.
    Dan
