586,912 active members*
3,584 visitors online*
    Dec 2009
    69
    linuxcnc gcode refresh in axis
    Does linuxcnc have a refresh/regenerate g-code after you, let's say, just did a work offset operation like Mach3 have? The gcode being used was generated with,say, 0 at left bottom corner and I'd like to make it 0 at the right corner. How do I update/tell the gcode in linuxcnc that I want a different work offset.
    Thank you. Sorry for my English.
    Jordan
    Dec 2005
    597
    Have you looked at the G5x codes? Sounds like they would do what you want.
    Or I'm not quite fully understanding what you would like to do.
    Mark
    Dec 2009
    69
    Thanks for the reply. Yes, I've been reading the docs closely and maybe g5x are what i'm referring to. I still have alot to learn though.
  1. help with 5 axis gcode
    By ethank in forum Rhinocam
    Last Post: 09-25-2020, 08:05 PM
  2. LinuxCNC axis calibration
    By bianchi in forum LinuxCNC (formerly EMC2)
    Last Post: 10-03-2012, 03:03 PM
  3. Eagle>pcb-gcode>linuxcnc question
    By de_structr in forum PCB milling
    Last Post: 06-28-2012, 01:40 PM
  4. X-Axis Stalling with LinuxCNC
    By mrfweet in forum LinuxCNC (formerly EMC2)
    Last Post: 03-18-2012, 10:41 PM
