586,645 active members*
2,889 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 Motor Tuning Issue
    Mar 2007
    11
    Question G540 Motor Tuning Issue
    I recently rebuilt my CNC setup with new motors and a G540 controller with Mach3. I have downloaded the XML file and have it installed. Everything with the G540 works fine to this point. I can jog the motors at a nice speed and everything "sounds" fine.
    However, when I attempt to calibrate the motors I start getting a strange problem. I am using the built in step adjustment and have everything set to the "inches" setting. I tell Mach3 to move the table 1.0" and it moved about 0.640" on the dial indicator. I typed that amount in and it informs that my steps will be set to 32XXX.XXXXX steps and I click OK. When I try to run it again to test the setting, the table moves at a super fast speed, so I adjust the velocity down to an acceptable level, then try the test again. For some reason, using the same 1.0" table move, the table actually only moves about 0.050". I have not changed the setting the calculator has inserted, just the velocity.
    I am at a loss, hopefully someone can offer a suggestion or two.
    The motors are standard Nema 23 425oz 8 wire motors that are wired bipolar series and are direct drive. As mention, the controller is a Gecko G540 and I am running it under Mach3. I know the computer runs Mach fine as I was using it before I swapped out the motors and the controller.
    Thank you in advance for your help.
    Apr 2007
    1955
    I don't know the answer, but it is interesting that the move is exactly 20 X off. I wonder if somehow a 10x micro step setting is somehow activted along with something to do with the 200 steps per revolution ?
    No idea, just throwing out ideas.
    Dec 2007
    2134
    Have you set the correct value for steps per pulse?
    cheers,
    Ian
    Jan 2012
    469
    I'm hoping you'll have fixed it by now, but.. For future reference.. :P I had a similar problem. Turned out the set screws on my couplers weren't tight enough!
    Anyway, always check for the simple stuff first!
  1. Motor tuning Gecko G540
    By bret4 in forum Gecko Drives
    Last Post: 04-18-2012, 11:06 AM
  2. Sweet Spot - Tuning G540
    By Bob La Londe in forum Gecko Drives
    Last Post: 01-20-2012, 12:13 AM
  3. Tuning motors issue
    By BrassBuilder in forum Benchtop Machines
    Last Post: 12-03-2010, 07:11 PM
  4. need help for g540 motor tuning.
    By Technogod in forum DIY CNC Router Table Machines
    Last Post: 11-07-2009, 05:47 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
