586,389 active members*
3,112 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Independent Cut depth two sided
Results 1 to 6 of 6
    May 2012
    Guys,
    I have a very asymmetrical part that I have setup to mill both sides.
    When setting the cut depth to make sure all features are milled for one sides creates a lot of air cutting when doing the opposite side.
    Is there any way to set the cut depth different for each side of the part ?
    meshCAM model: http://www.cboservices.net/cad/FuelCapMedium.mcf
    STL: http://www.cboservices.net/cad/FuelCapMedium.stl
    Chris Olsen
    Apr 2003
    178
    Looking at the part, it seem like it would be OK if you have the "Machine Geometry +" option selected instead of the "Machine Whole Stock" option. This will keep the tool within the outline of the part plus some margin rather than remachining all of the surrounding area on the second half.
    For the "Machine Geometry +" value, I like to use the diameter of my largest tool.
    -Robert
    May 2012
    Toolpath
    I did not upload the toolpath settings I was using previously.
    I double checked them and they do specify the Machine Geometry.
    What happens in the waterline path ends up cutting way deeper than is needed, before the 'Cut along X' paths start.
    Not a huge deal but it does increase the machining time a fair amount.
    Here is the toolpath file if that helps:
    http://www.cboservices.net/cad/FuelCap-Bull.tps
    Chris Olsen
    Apr 2003
    178
    Got it- that is a tough one to fix right now in an automatic way. The work around is:
    1. Set the max depth for the top and generate the toolpath.
    2. Save the toolpaths
    3. Set the max depth for the bottom and generate the toolpaths
    4. Save the toolpaths
    5. Machine the top from step 2 and the bottom from step 4.
    Not optimal but it works.
    -Robert
    May 2012
    That should work
    Robert,
    That sounds like a viable work around. For sure would not expect it to automatically try to figure this out. Was just thinking a future change would all the user to specify a different cut depth for the top and bottom as an option.
    Thanks for the help
    Chris Olsen
    Nov 2014
    1
    Re: Independent Cut depth two sided
    This is very nice post thanks!
    Johni Imtiaz..!!
  1. Cutting Depth Issues with 2-Sided machining on MeshCAM
    By Skump in forum Uncategorised CAM Discussion
    Last Post: 01-06-2014, 07:01 PM
  2. independent-universal THC device
    By PromaElektronik in forum Waterjet General Topics
    Last Post: 11-06-2012, 07:34 PM
  3. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  4. Does Solidcam work independent
    By crkdinesh in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-26-2009, 08:37 AM
  5. Independent Sodick Tech??
    By XYZ machine in forum EDM Discussion General Topics
    Last Post: 01-13-2009, 02:47 AM
