586,753 active members*
7,198 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > KIA VX-500 Y-axis home/reference off
    Sep 2006
    94
    Hello,
    I have a KIA VX-500 with a Fanuc Oi-MB control.
    My problem is that the Y axis will not reference. I get an overtravel alarm when I try to reference Y. It is a soft overtravel. The tang that trips the switch is just over an inch away from tripping the switch.
    Any ideas?
    Heath
    Jul 2010
    104
    First thing I would try would be to back off all axes from zero, estop & power off control. Power up control while holding both the CANCEL and the letter O/P key until the power up is complete. Hit standby, zero return as normal. By holding the keys down during power up, it cancels the soft limits of the machine allowing you to rehome the axis without overtravelling. Do not, under any circumstances, use any other key combination during power up without first knowing what exactly the combination does. You could have disasterous results.
    Sep 2006
    94
    ad64075,
    Thank you. I will give that a shot.
    Jul 2012
    did it work?
    i would reccomend you to disable the Y axis software limit switch
    1320 Coordinate value I of stored stroke check 1 in the positive direction on each axis
    1321 Coordinate value I of stored stroke check 1 in the negative direction on each axis
    as the reference position is going to + direction you should write in parameter
    1320 Y = 999999
    to disable the switch
    drive the reference position and input the original value back again
    oh i see ad64075 recommended the same just in another was sorry
    Sep 2006
    94
    khaot183,
    Yes, it did.
    Just tried it a few moments ago.
    Thanks, ad64075
  1. Dyna 20 won't Z reference home
    By 3bmachine in forum Dynapath
    Last Post: 04-21-2012, 10:51 PM
  2. Reference for C-axis
    By sinha_nsit in forum Fanuc
    Last Post: 01-26-2011, 09:50 PM
  3. Fanuc 3M need reference home parameter
    By teal854t in forum Fanuc
    Last Post: 02-07-2009, 08:32 PM
  4. wandering home reference position
    By howd in forum Fanuc
    Last Post: 10-05-2008, 07:22 AM
  5. Optical Limit/Home/Reference Switches
    By redbaron in forum DIY CNC Router Table Machines
    Last Post: 02-07-2004, 02:47 AM
