I hope someone on this forum could help me out. I recently bought a 3D printer that runs off the TB6560 4 Axis controller board, and Mach 3. I have everything setup and I am able to get the X, Y and Z axis working (I can manually move them by jogging them in Mach 3). I am however having trouble with the A axis.
So far I have tried the following.
1. Made sure my Mach 3 config matches the recommended settings.
2. Made sure it was not the stepper motor wiring (switched out the motor with one that I know works)
3. Made sure the pins gets voltage from the parallel card.
When I jog the "A" axis in Mach, the A Axis LED flashes on the board, but the motor just sits there (It does not even lock up when Mach is loaded).
Is there anything else I can try? Would it be possible to modify the board by installing an EasyDriver for the A axis?
I have asked these questions on the support forum for the Printer I bought, but so far no-one could help.
