Hello,
I have been tweaking my first CNC build and use of Mach3, so far it works...
But If I need to set the cutting speed way down low/slow for cutting something hard it also then moves relay slow when traversing from point to point (when Z is up)...
Is there a way in Mach3 to set cutting/working speed -vs- a separate speed for non cutting/traversing speed?
Thanks for the help.
Shane
