587,006 active members*
3,279 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Spindle Won't Reach Speed after Brake On while Spindle Start
Results 1 to 20 of 45
    Nov 2006
    925
    So what was wrong with the spindle drive?
    Jun 2012
    516
    Quote Originally Posted by gridley51 View Post
    A diode, and a wirewound resistor on the MTI-1 board had gone. The board was blackened a little near the resistor. I also replaced the caps on that board, but all of them measured OK before replacement.
    Later after that repair, I programmed a M03 S4000, and didn't turn off the brake. The SCR that is on the MTI-1 board fried. I replaced that and the spindle runs - although the KTK drive isn't setup quite right. There is a serious overspeed, which I compensate for using a factor (see previous posts). CNC tapping works just fine like this and I wonder if the speed control using the factor (speeds measured with cheap laser tach) are more accurate than the factory setting. So, since that system works and has for more than a year, I haven't gone in to try and solve the overspeed issue.
    Jun 2012
    516
    Re: Spindle Won't Reach Speed after Brake On while Spindle Start
    Quote Originally Posted by mflux_gamblej View Post
    I know I posted something on another related thread, but the overall cause of the issue in the first place was that there was a diode in the CNC cabinet on the right side that didn't get soldered on at the factory. It was an open circuit, and just so happened to be a diode that controlled the machine's ability to operate the automatic brake. That is why the brake didn't shut off for me when I programmed M03 S4000, and trashed the MTI board, and so on as detailed below. silly, and serious all at once. 'thanks' bridgeport!
  1. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  2. RF45 issue: spindle slow to reach max rpm
    By spv123 in forum Benchtop Machines
    Last Post: 01-07-2013, 05:50 AM
  3. lost brake and spindle speed control on r2e3
    By jerry whitworth in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2012, 05:04 PM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. Controlling Router Spindle Start/Stop/Speed
    By AntonCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-17-2009, 09:04 PM
