586,599 active members*
3,486 visitors online*
Results 1 to 8 of 8
    Definition of "minimum shaping character"?
    I am new to laser cutting and need to know what "minimum shaping character" means.
    Can anyone explain or point me in the right direction to a definition?
    Thanks!
    Probably minimum readable character - accomplished when you going downhill with the wind from behind
    Oct 2007
    385
    I am with Rodney...it is the smallest possible character that is readable.
    Milt
    OK, so this doesn't have anything to do with how small a shape can be cut? This has to do with laser engraving a letter (character) and it's readability?
    The laser I am looking at has .001" resolution which sounds OK but ".040" minimum shaping character" didn't mean a thing to me. I'm a machinist not an engraver. I assume the .003"-.004" diameter laser burn has some effect on how small something can be cut from the standpoint of geometry. Obviously I can't cut a .002" diameter hole but I assume I can cut a .005" diameter hole?
    Oct 2007
    385
    You have me on that one. Someone with more experience will have to chime in. I do know that I get a smaller laser spot using a 25.4mm focus lens, but that is mainly for engraving. Sorry, not much help on this one.
    Milt
    Nov 2010
    787
    "minimum shaping character" means NOTHING.
    This is only trading ble, ble, ble
    Every "newbee" looks for any numbers to compare machines quality.
    So sellers found "minimum shaping character".
    And now EVERY chinese machine makes "minimum shaping character 1mm"
    This is 100% trading fake.
    Nobody ever tried to cut this 1mm "shaping character"
    CNC lasers, constructions, service
    You will struggle to get a spot size of 0.005" with the types of lasers referred to here. Even with ultra short focal length focus lenses , work on a value closer to 0.007-0.01". A readable character would be 5-7x the spot size. (1mm at 5x assumes a spot size of 0.008")
    There is also another consideration re smallest character size , 1mm is really not that readable under normal circumstance and 1mm might only be achievable in a vector type mode and not in raster (back and forth scanning)
    As to laser machining , apart from spot size , there are all other types of considerations as to how fine you can go like the motion system , the focus lens , the beam quality , how the material reacts and so forth. I doubt you will be able to cut a good round 0.005" hole.
    Rodney,
    Thanks! Your info is very useful and was just what I was looking for!
  1. "Chinese" spindle minimum speed
    By Hirudin in forum Spindles / VFD
    Last Post: 12-21-2019, 01:47 PM
  2. Milling Text character "Ø"
    By rayzer in forum EdgeCam
    Last Post: 07-03-2009, 02:36 PM
  3. Is there a "minimum velocity" for steppers?
    By rogerer in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 11:52 PM
  4. "shaping" aluminum?
    By smythe in forum MetalWork Discussion
    Last Post: 08-06-2004, 05:35 PM
