586,651 active members*
2,874 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Noob help with part design / milling
    Jun 2012
    Hi folks,
    I am new to CNC and have been doing a lot of research to learn and understand the process and think I have most of it. I have a DIYDesktopCNC as my learner and have a part designed and ready for milling. I understand that I have to take it to CAM to g-code then something like Mach3 to mill it. The part will be milled from aluminum and I will need to add 'tabs' (see sample picture below) to keep the part in place as its being milled from the stock .
    A few questions:
    1) What is the CAD term/lingo used for adding these 'tabs'?
    2) Where / which software do I add these tabs? In the CAM package? Or do I include them as part of the design of the part itself?
    3) Any suggestions on how large / thick to make them? In the sample below, the person used 4 tabs.
    4) other suggestions?
    Mar 2006
    489
    1) "Tabs"
    2) Depends on what CAM software you are using. Most 2 1/2D CAM packages have the ability to add tabs to your part. (SheetCAM works well for this)
    3) They don't have to be very big to hold the part securely. Make the length equal to the tool diameter and the thickness equal to 1/4 the tool diameter. Use 3 tabs as a minimum. The tabs shown are a lot smaller. This may be due to experience with cutting this particular part. You will find out how small you can make them with experience.
  1. Good ole fashion Noob question about motors for my design
    By Azonic in forum Community Club House
    Last Post: 03-21-2009, 11:57 AM
  2. Verify Cut part to Design part.
    By CaseyCAM in forum NCPlot G-Code editor / backplotter
    Last Post: 11-02-2008, 03:22 AM
  3. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
  4. I'm a nOOb looking for a router design
    By zachjowi in forum DIY CNC Router Table Machines
    Last Post: 03-03-2008, 12:14 AM
  5. noob alert: recomend a design for these steppers
    By pen25 in forum DIY CNC Router Table Machines
    Last Post: 03-02-2005, 09:31 AM
