1.Adopt constant power water-cooled frequency spindle, high speed, low noise and long life.
2.Adopt constant power water-cooled frequency spindle, high speed, low noise and long life.
3.Three axises are precision ball screw vice transmission, reasonable structure, stable performance, good weight bearing ability.
4.This machine is mini machine, low price, high performance, especially suitable for home and small enterprises,institutions* to do processing .
5.Users can* assemble electric spindle and driving control system according to their own needs.
Specification:
X Y axis working area 300 x 200mm
Z axis working area <60mm
Table size 370mm x 440mm
Max. speed 0 - 4,000mm/min
Max. working speed 0 - 4,000mm/min
Working delicacy 0.015mm
Reposition accuracy 0.05mm
Max. feeding height 60mm
Command G code *.u00* *.mmg* *.plt *.nc
Software Type3, Artcut, Artcam, Ncstudio software
Max. power consumption 1.2KW
Spindle 0.8 kW variable speed, water cooled motor
Spindle speed 24,000rpm
Work type stepper
Working voltage AC 220V, 50/60Hz
Memory 32M
Manner of receiving data USB OR PCI*
Running circumstance temperature 0 - 45℃
Relative humidity 30% - 75%
Weight 57kg
