I watched with amusement the other thread discussing toolchangers, and the pros and cons of Geneva mechanism vs stepper drive. It seems some people consider the Geneva to be mechanically complex and difficult to fabricate, and to have all kinds of shortcomings. No doubt some of the doubter have never built one, and perhaps never took the time to really understand how it works.
As I am in the process of building a carousel-style ATC for my knee mill, I chose to go with a Geneva, and today I spent about 90 minutes fabricating a prototype out of scrap aluminum. I'm happy to report it works absolutely perfectly! Even running bone dry, it is silky smooth and quiet in operation, positions perfectly at each tool station, and locks in place with only just barely perceptible angular backlash - certainly nowhere near enough to cause any kind of problem whatsoever.
I expect it would have taken just as long, and cost a lot more, to do the same with a stepper and belt drive. To drive it, I will be using an off-the-shelf $34 gearmotor from McMaster-Carr, which will give rotate one tool position in barely a second, making the worst-case rotation time for a 12-tool changer only six seconds. Overall, I expect worst-case tool change time should be about 15 seconds start to finish.
Ray L.
