587,043 active members*
2,992 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How to tune the torque loop of my Z-axis?
    Jun 2005
    9
    I am having overcurrent faults from time to time on my Z-axis of my milling machine. This is probably the result of bad tuning. For the X and Y axis I tuned the torque loop first, then the velocity/position loop. The problem with the Z-axis, is that it's very heavy and moves down very quickly when the brake is not applied. I have tuned the torque loop with the motor dismounted, and I noticed that the brake is not being applied during torque tuning. How can I properly tune the Z-axis while the motor is mounted? Or is the load of no influence on the torque tuning?
    A second thing I noticed, is that when I try to tune the velocity loop of the Z-axis, the target velocity is not a nice and straight up/down slope. But a slope with many "peaks" on it. Instead of raising the speed in a linear way, it goes up and down a few times before it reaches it peak value. The X and Y don't show this behaviour, is it because of bad torque tuning?
    Hope someone can help me.
    Jonathan
    Feb 2012
    149
    Do you have an output that engages the z brake? I set the output to enable the brake during tuning, the servo overcomes the brake and allows me to tune. Another method is disconnecting the power to the zbrake, this should engage it. Then do your tuning. As far as the curve, do you have any storage scopes available? If you can monitor position error while executing a repeatable move ie a circle you use it reduce error after making parameter changes. Providing your setting are somewhat close to begin with.
    Sent from my BNTV250A using Tapatalk 2
    Sep 2004
    1207
    Few questions to be able provide better answers:
    *What type of motor? AC/BCLDC or DC?
    *Please send current GDtool settings file here
    *Also send tuning graphs as PDF
    Anyway tuning torque for Z should be no problem because it doesn't matter whether axis rests on bottom of travel or is held by brake. So the problem probably is something else.
  1. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  2. Z axis leadscrew tune
    By SHMUEL in forum Taig Mills / Lathes
    Last Post: 08-22-2011, 10:48 PM
  3. CNC conversion typically open loop or closed loop?
    By foobar42 in forum Benchtop Machines
    Last Post: 10-30-2009, 01:21 AM
  4. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  5. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
