586,419 active members*
3,189 visitors online*
    Jul 2009
    5
    Question Anilam 6000M Halted during G84
    Running a Chevalier 14/18 with the Anilam 6000M. Ran about 400 cycles in the last few month. Now it stops when it goes to do the G84 Rigid tapping.
    The display says HALTED. Also no error code. Machine is is stops with the spindle rotating at tapping speed but it will sit there all day with no error code. It will run about 2 hours in the morning then it stops.
    Mar 2011
    67
    Can it do a tool change after it stops in a G84? Or do an M19 spindle orient? I wonder if there is a problem with the reference mark on the spindle encoder getting through to the CNC chassis.
    Apr 2002
    5003
    First you should try, to remove and reconnect the connectors of the motor and the control for this motor.
    It should often happen, that the connectors have bad contact, through water or the shake from machining. If this doesn't work, you should use a oszilloskope to see, if all signals in the connector are ok.
    Jul 2009
    5
    This turned out to be the spindle encoder. Had to send spindle motor to manufacturer for repair. Encoder is integrated with motor somehow and Hieidenhein has a special ociliscope for setting it.
  1. Post Processer for Anilam 6000m?
    By matthew6060 in forum GibbsCAM
    Last Post: 07-26-2015, 08:21 PM
  2. Anilam 6000M - Fryer fatal motor error
    By paradiddle in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2012, 07:16 AM
  3. anilam 6000m
    By slug in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2009, 07:39 PM
  4. system halted!
    By kokai in forum Milltronics
    Last Post: 05-03-2008, 04:48 AM
