586,392 active members*
3,038 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > GE Fanuc 0-M series parameters required urgently
Results 1 to 13 of 13
    Jun 2012
    Exclamation GE Fanuc 0-M series parameters required urgently
    Good afternoon all,
    I have a Cincinati Milacron Sabre 750 mill with GE Fanuc 0-M panel.
    Someone has deleted the entire memory along with all the parameters.
    I am completely new to this machine and have no reading material or manuals for reference
    Would someone kindly be able to send me either a pdf. manual with the values which i can punch in by hand or, a file compatible to send via RS232 ?
    Many many thanks in advance.
    Dale
    Aug 2010
    27
    Hello Dale,
    You have bigger issues. Several of the parameter are unique to your machine. The list is not generic. You will only type in the number if you have a printout from your machine.. See if the manufacture has a print out they can send you. If not it could be days of trail and error. What series of the O-M. A,B C or D.
    IT IS THE PARAMETER OF (FANUC O-M)
    Attached Files Attached Files
    Oct 2013
    40
    Re: GE Fanuc 0-M series parameters required urgently
    hello faiz how r u i am zain ali from Pakistan and i am doing troubleshooting of cnc machine in Lahore.id is [email protected]
    cell number is +92-332-4244023..please contact.
    not (OMC) is (OMF)
    Apr 2015
    5
    greetings to you faiz . this parameters are of FANUC O-M but is O-MC ? or other
    Mar 2014
    3
    your parameters doesn't include the 900s
    Quote Originally Posted by HASSIA View Post
    Proprietary information
    Apr 2009
    1379
    Unless these option params are for a very similar machine, activating the wrong option can cause serious problems.
    Mar 2014
    3
    Thanks faiz!!, the main problem that I got when put the wrong parameters was...
    Attachment 239754
    Attachment 239756
    I'm looking fot the supermax max 3 (YMC-VMC-72A) WITH A FANUC 0M CONTROL parameters
    Apr 2009
    1379
    You should first enter all 900 params (options), cycle control power and then enter the other params and diagnostics.
    Apr 2020
    2
    Hello,
    Need help with old Fanuc O-M. (Supermax YCM-VMC-72A)
    I lost parameters (I think battery problems). I put parameters manually, looks ok, but found same different.
    1. I cant write programs in memory (appears alarm 086). Programs in memory 0, but memory are full.
    2. Do not switch gear box to second gear. (2 gears box.)
    3. Not very big problem: Zero return all axes works when hold the button (before was automatically by pressing once)
    Maybe I do not write good parameters or write not all (cant reach parameters from 10300 to 10499)
    Maybe someone have the same machine and I can check parameters with good one.
    Thanks for some ideas,
    Dec 2003
    24223
    That was 5 months ago, hopefully he has by now!!
    Al.
    Albert E.
  1. Parameters needed urgently
    By m4martin in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2014, 06:19 AM
  2. fanuc series OM parameters lost
    By m_ghaff2000 in forum Fanuc
    Last Post: 01-24-2014, 08:42 PM
  3. Fanuc O-TC Series Parameters/master Program
    By lbell15 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2013, 06:16 PM
  4. Required ROM IC's Data for FEMCO CNC Turning Center With Fanuc 10T Series
    By james anderson in forum Wood Lathes / Mills
    Last Post: 12-12-2012, 09:49 AM
  5. Replies: 0
    Last Post: 11-11-2011, 04:32 PM
