I recently acquired a 40W generic chinese laser (aka K40) which came with Moshidraw 2012 (USB controller card).
As delivered the machine has various unnecessary problems that I am fixing:
Fume extraction
Travel (maximising available)
Added air assist
Improved table
To Moshidraw 2012:
A buggy piece of software, but if treated right can give decent results. Especially considering the alternatives are to spend hundreds adapting to Mach3 or linuxcnc (and make engraving more difficult) or a DSP (at the cost of >$600 with stepper drivers)
Interface
My install has buttons / functions that are obscured and require moving of toolbars / stretching to reveal.
Half the drawing functions were hidden - drag the edge right
Working with shapes / design
You can design within moshidraw to a basic level
Tips:
Positioning is done based on the centre of an object
Never drag objects if you want them to stay the same size. Moshi will often slightly resize things even if you grabbed them in the middle to drag and place them. If your object is anything more than a simple square you won't be able to accurately restore line lengths etc
I prefer to design in solidworks or other software. You can do this quite successfully (I've tried Coreldraw X4 and Solidworks 2011). You must save in R14 version of .DXF. Then import this file into a new moshidraw document.
Solidworks .DXFs seem to import as white lines - click on the line colour box and it will switch to black.
To select an imported object click on it's entry in the layer tab
Again never use dragging to move an object - it will change size, and not necessarily in a linear way. Use the x,y coordinates in the top bar.
You can't rotate in moshidraw, so you'll need to do it in your design software.
Engraving and cutting on the same piece accurately
Moshi has an 'assist' layer function - this is similar to construction lines in Solidworks. The lines appear on the drawing but do not get cut / engraved.
To engrave then cut:
1. Draw your outline cut
2. Make sure it is selected and tick the 'assist' box - it will be renamed to 'assistxxxx'
3. Draw your engraving (text, whatever)
4. Select everything (engraving and outline set to assist) and output to machine
5. Engrave with whatever settings
6. Go back to drawing window (close machine output)
7. Select the outline to be cut and untick the assist box
8. Select the engraving and tick assist (may be unnecessary, further testing needed)
9. Select the outline to be cut and output to machine
10. Cut at whatever settings
11. Enjoy!
This works the same with imported stuff. Select the outside cut and make it assist - it's still there for the purpose of the machine position when it engraves / cuts stuff within that space.
Engraving
In the machine output window there are a number of options that affect engraving.
Normal & versa - aka normal or reverse (mirror image). Versa is used for engraving on the back of perspex or glass, so that you can see the image through it (the correct way round) but the surface is flat.
Convex & concave - set whether inside or outside the lines is engraved. E.g. if you have text, one option will engrave within the text (leaving it recessed), the other will engrave the area outside the text (leaving the text proud).
To be tested:
Distance setting (x lines) - suspect it relates to engraving resolution
Add size
I'll add and update this as I find further things.
Any tips anyone has will be appreciated.
