Hello everyone I'm new here and also a total CNC newbie and I have a question or two. Ok my boss wants to convert our x2 mini mill to CNC so I've been researching some of the kits out there and I've narrowed it down to the CNC Fusion kit or the Stirling Steele kit. We really liked the Steele kit because it allows you to keep the hand wheels in order to still use it manually. But then I came across this post on the CNC Fusion forum.
"One good reason not to put handwheels on your mill, is the stepper motors act like mini DC generators when you spin the shafts. (try wetting your finger, and hold the lead wires while spinning the motor shaft. ZAP) That current will back-feed into your drivers, and I can’t imagine that can result in anything good. Yes, you can disconnect them every time you want to use the mill manually.....
Also, the ballscrews turn so freely, they the table will not stay in position as with the stock leadscrews, unless you use the gib locks for every cut, which would be a pain.
So it is technically possible to use dual shaft with handwheels on the shafts, but we do not support or recommend doing it."
Has anyone out there run into any problems blowing up or damaging the motor drivers when using the hand wheels? Also has anyone had problems with the table not staying in position while having the hand wheels still attached as we plan on converting over to ball screws due to the large amount of backlash we are getting with the normal lead screws?
