586,594 active members*
3,044 visitors online*
Thread: Masking
Results 1 to 8 of 8
    Jun 2007
    18
    Question Masking
    Hi All,
    When making V carve signs I stain the timber first then mask the area to be routed then v carve through the masking which makes painting the letters relatively easy. The hitch is finding the right type of masking tape, the problem is that most seem to tear rather than cut a neat line which leads to bleed of the paint. If I use a stronger adhesive tape they either leave a residue or peel off the stain or both. Can anyone recomend a suitable masking material please?:
    Jan 2007
    229
    Signmask of assorted types, from signwriting suppliers ?
    Jun 2007
    18
    Masking
    Stewey,
    Thanks for that, I'm on to a supplier to get various samples and see which works for me. Cheers,
    Zimba.
    Jan 2007
    723
    Try sign vinyl from US Cutter or such. it comes in many sized roles and is easy to apply and remove. I use it at my middle school with the kids and as long as you do not apply paint heavy you might not have to seal it! You can also spray paint the surface before you carve and you will get the surface one color and the grooves another.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    May 2006
    202
    There's a step by step on the topic of masking rough cedar on 3D Sign Forum | A School for Dimensional Sign Artists. The standard masking vinyls can't be used on rough or textured surfaces.
    Mar 2013
    I was search your question in Google and found this url.
    google.com/patents/US5292402
    I hope this will be useful for you and here you can find the suitable masking material.
    Aug 2010
    17
    thinned down plastidip, it will peel off easily and leave no residue
    Nov 2010
    71
    I use OraMask 813. I buy it from OraMASK 813 Stencil Film - 24 inch x 50 yds - Sign Supplies and Equipment. Been using it for years and works great.
    http://mikeswoodsigns.com/
    Mike Kearns
    noveltysigncarver.com
  1. Laser masking? what do you do?
    By bpoulin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-02-2016, 04:04 PM
  2. VCarving Masking question
    By jburks in forum DIY CNC Router Table Machines
    Last Post: 05-08-2012, 03:32 PM
  3. masking film
    By 1ctoolfool in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2009, 02:42 AM
  4. Looking for a masking film for soft stone and wood.
    By Larne W in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-16-2008, 03:08 AM
  5. Masking machined parts using vinyl
    By Brookway in forum Mass finishing equipment/media/strategies
    Last Post: 07-02-2007, 06:30 PM
