I have a 1989 Sabre 750 with Fanuc 0-MC. Great, strong machine.
I've had it for about 7 months, and have been living with this problem but now it is holding me up on a job. It seems as tho when the torque to either the spindle motor or an axis servo spikes up a little the machine will feed hold itself automatically. If the load is constant (say face milling) it will take heavy loads all day long. Currently I have a job and am using some indexable carbide drills (1" and 5/8" dia) to peck drill some holes and almost at every peck the machine will feed hold itself. Sometimes it stops during a cut, sometimes when it's retracted to break the chips. I'm definately not overloading the motor to any extent whatsoever with these tools. To complete the holes I need to stand at the control and constantly press cycle start and let the hole finish. Machine will also do the same thing sometimes when say endmilling into an inside corner, or doing other work which may quickly load up the spindle.
Any ideas?
I've checked the Spindle Drive unit and no alarms are ever displayed when this happens. Same on the control itelf, no alarms are displayed. Only my feed-hold light turns on.
