587,030 active members*
3,616 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > xml found not found when trying to simulate?
    Jun 2012
    514
    why is the popping up...? UsingV25
    It pops up and never even trys to start a tool path simulation
    anyone have any clues? or answers.... Thanks!
    Dec 2008
    4548
    Have you set bobcads launch Icon to run as administrator?
    Have you made some type of install path other than default?
    C:\BobCAD-CAM Data\BobCAD-CAM V25\MachSim\BobCAD_Mill\BobCAD_Mill.xml
    Jun 2008
    1838
    This happens if you create a new machine and delete the original "BobCAD 3 axis machine", this deletes the original XML file so you will need to put that file back in to your BobCAD-CAM Data folder here:-
    I have attached the files you need here Zipped up in it`s original folder, just unzip it and then paste the folder as is into the \MachSim folder, that should get your sim working again.
    Then just add a new machine and then select that as the default and leave the original one in the file
    Hope that helps
    Regards
    Rob
    :rainfro::rainfro::rainfro:
    Attached Files Attached Files
  1. NVM..FOUND IT
    By xclr82xtc in forum Solidworks
    Last Post: 03-09-2011, 01:58 AM
  2. no sim found
    By wronggrade in forum Mastercam
    Last Post: 11-18-2010, 12:27 AM
  3. I have found what I am looking for.
    By fred.rowe in forum Want To Buy...Need help!
    Last Post: 09-08-2008, 04:55 PM
  4. I found...
    By amurphysmu in forum DIY CNC Router Table Machines
    Last Post: 09-13-2005, 07:50 PM
