Originally Posted by
ErnieD
I have just run into a problem where I am trying to subtract a cylinder from an object. When I choose boolean subtract, select the item that I want to keep, select the item that I want to subtract, right click in the work area and left click ok, the item to be subtracted does not go away. If I slide the cursor across the entity on the screen everything is selected as if it were one solid. It is as if the subtract button is now the add button.
Has anyone encountered this phenomenon and if so what did you do to correct it?
Ernie
