587,048 active members*
3,134 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Burn Table Lead in lead out
Results 1 to 8 of 8
    Dec 2005
    19
    Everyone
    I am trying to use Bobcad for my burn table.
    Which it does fine for the outer shapes but not holes.
    I would like to have the lead out to have a negitive
    overlap. I attached a pic from our old software.
    The green circle is the diameter of the torch flame.
    White is the path
    Red is rapid.
    Also you can see the lead in is an arc.
    Sorry I am noob If there is a better way thats ok also.
    Later JeReMy
    Mar 2012
    1570
    Your image did not show up...
    Question, you want the cutting to go past the lead in point on the profile you are cutting.
    So it would lead in at point A, cut around the shape, then lead out at point B which would be past point A, correct?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Dec 2005
    19
    Sorry the action photos didn't work.
    Thanks so much but the Overlap will only "add to the cut".
    I want to "subtract from the cut" If I have a negative number
    it goes to zero. I think I will have to draw a tab on my holes.
    Later JeReMy
    Mar 2012
    1570
    Ok you want to leave material left as a tab?
    If you have the nesting software you can set a tab. Currently BobCAD does not offer a tab option for profile cutting, it's only available with nesting.
    Al DePoalo
    Dec 2005
    19
    I tried nesting and I can't get it to change the start point.
    With some shapes this fine but others it doesn't work
    The software has you pick geomerty not a finished part with tool paths.
    I tried the nesting a only few times so I may be doing something wrong.
    I have never used it for production.
    Later JeReMy
    Mar 2012
    1570
    You have to use the contour option to "force" the start point for profiles used in nesting.
    The contour menu is a grouping feature. It groups geometry together setting the start point and direction of the cut.
    Al DePoalo
    May 2012
    I have this same problem in v24. Some lead in points are in the part and some not and it seems at random even with same file used twice.I emailed tech and they sent me invitation to purchase the subscription. All updates downloaded
    Dec 2005
    19
    I tried my best with contour option to "force" the start point for profiles.
    Which i got to work. But it only changes the start. I would like the holes
    to have one type of lead in and the perimeter to have another.
    I must me doing something wrong.
    Thanks for the help!!!!
    Later JeReMy
  1. Burn Table Lead Out of Zero ERROR
    By JINDA in forum BobCad-Cam
    Last Post: 05-10-2012, 06:33 PM
  2. lead screw diameter for 6 ft table
    By tkms002 in forum DIY CNC Router Table Machines
    Last Post: 03-27-2011, 07:19 AM
  3. Lead In Lead out Speed Problem
    By JWB_Machining in forum Mastercam
    Last Post: 12-12-2008, 02:33 PM
  4. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  5. lead in-lead out on surface toolpath
    By Tugiyana in forum Mastercam
    Last Post: 05-07-2007, 11:16 AM
