Hello friends,
Here I am on the machine with Fanuc spindle unit A06B-6052-0004 and it gives ALARM 12 (8+4) (High current DC Link) when starting M3 (M4) S300 and above. If I start S100 it begins to rotate jerking, pulsing and if I began to increase S by 100 it can go turns to S1000 and then gives Alarm 12. But if I start S300 it gives directly Alarm12.
I measured the resistance of the motor- it’s OK , to Earth also by megaohmmeter there’s not problem. I measured by Ohmmeter Transistor power module – A50L-0001-0209 : between B1-B2-U0, B3-B4-V0, B5-B6-W0 the measurings are the same. (But actually I don’t know how to measure that Transistor module.)
I found a post in another theme:"FANUC OT B Spindle rpm fluctuating and causing 1008 Spindle ...": of : tmbruno28 "ok, first thing, you have to check sensor signal by an oscilloscope turning spindle by hand . you have check points at the bottom of the pcb, just near CN2 connector .they are called Pa,Pb, Ra, Rb. You must found a sinusoid of about 3.5 volts on the a, and continuous 3 volts on the two others. "
So I started S100 M3 and measured by multimeter between Pa and Ra – 0.03V. Between Pb and Rb - 0V.
Unfortunately I don’t have with me oscilloscope and couldn’t find oscilloscope here , but if you can give me some advice – is it possible that Pulscoder is not OK ?
