586,379 active members*
2,884 visitors online*
    Dec 2004
    174
    Moving to mach 3 need exact mach 2 screen
    I would like to migrate to mach 3 from mach 2. My holdup is that I need to keep the default mach 2 standard run screen, which I have not been able to find. The Mach 3 default screen is different and doesn't include all the functions I have been using. I expect I could make a new screen given enough time but just need the simple layout.
    Carl
    I have a copy of Mach3 R1.0 which might still have the old screens, but I'm not sure. PM me your email address and I'll send it to you. You'd have to install it, and back up the screen files, then install the latest and load the old screens. But, again, I'm not sure if it's in there though.
    Dec 2004
    174
    Ger
    When you mentioned the old versions, I looked through my old downloads and found an acceptable screen. Thank you.
    Carl
