586,666 active members*
3,630 visitors online*
    Oct 2008
    2100
    ??? For X4 - X5 Owners
    Is there any room to tweak the machine and get a little more travel with out a major rebuild? The X5 Speedmaster with the optional extra high (35K) speed spindle is the closest (spec) machine to what I do the most of, but I really need a hair over 12" on the X axis.
    The Tormach 770 isn't bad, but it tops at 10K. I have Hurco with a lot more travel, but it tops at 3K. (Yes I have seen the speeder that Tormach makes that hasn't been in stock for a while.)
    The X5 Speedmaster would be very close to what I need for a high speed machine at the price if it had just a smidge more travel.
    Bob La Londe
    http://www.YumaBassMan.com
    Apr 2006
    844
    currently x5 only at this size.or your take off the optical sennor?
    Direction,Commitment,Follow through
    Oct 2008
    2100
    Are you saying that there is some more room for mechanical movement if the limit sensor is removed or relocated? How much room?
    Bob La Londe
    Apr 2006
    844
    i think around 30mm
    not too much.but have some space.
    Oct 2008
    2100
    30mm is over an inch. That would fit it just over my primary work envelope. Thank you.
    Bob La Londe
  1. Need help from Plasmacam owners
    By welder66 in forum PlasmaCam
    Last Post: 11-01-2010, 02:48 PM
  2. Any DT owners in SE Ohio?
    By redfarm in forum DynaTorch
    Last Post: 10-10-2010, 03:58 AM
  3. KX1 Owners LOOK!
    By deanler in forum Benchtop Machines
    Last Post: 06-27-2010, 01:11 AM
  4. Any LMS CNC owners out there?
    By slawsonb in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2010, 04:09 PM
  5. Any CS 250 Owners out there?
    By Polishpiper in forum Mori Seiki lathes
    Last Post: 06-15-2009, 11:40 AM
