586,648 active members*
2,455 visitors online*
    May 2012
    Hurco Hawk 5D
    We were setting up the referance axes, the X axis in fact.
    Came up against the stop so limit switch activated the emergency stop.
    Display said press "reset", but cannot move bed in any axis!, "fault" keeps registering emergency stop etc etc
    Is there another physical reset anywhere?
    Sep 2008
    28
    Its been a while since i worked on a Hawk (Dynapath) but i do remember the same problem after an overtravel...
    Isn't there a overtravel release on the back of the electronic box ? Or on the side of Monitor box ?
    It didn't always work for me either so do this...
    ...Turn the power off, manually turn the ballscrew under the table (wear gloves)
    to get in front of the limit switch again... turn power back on ... jog with axis at least 4 inches (100mm) away from switch and re-home the axis.
    Good luck
  1. hurco hawk dynapath
    By moldman3 in forum HURCO
    Last Post: 11-04-2011, 10:32 PM
  2. Hurco Hawk 40
    By brucemazor in forum HURCO
    Last Post: 08-19-2011, 05:56 AM
  3. Hurco Hawk 5D
    By sensph in forum HURCO
    Last Post: 09-22-2008, 06:02 PM
  4. Replies: 4
    Last Post: 07-26-2008, 08:03 AM
  5. Hurco Hawk 30
    By jack_1960 in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2007, 01:27 PM
