I took on cutting Hpl samples for a local distributor on my CNC router, sourced a diamond bit, 8mm, which cuts okay, I started with A5 samples (about 190 x 140mm) so they were large enough that the vacuum held them in place.
Now I have started cutting the small samples, I have resorted to leaving tabs on them to hold them in place, HELP, this is a. Not really getting a good result and B. there are 900 pieces per sheet.
The samples are about 65mm x 40mm with a hole at one end and radiused corners.
Can anyone out there offer some advice, would be greatly appreciated.
Is my CNC router the machine for this or is there a better way?
