Just want to share my new set-up,
After all helps from Tom I am able to make my router running,
- My router is 48x48 DIY build
- Gantry weight 150 pounds
- Kflop + Kstep
- Vexta stepper pk299-f4.5
- material is 3mm thich, it is uluminum composite,1 gem thick alu on both side,plastic composite at the middle,
-Kflop+Kstep+power supply, no breakboard needed, very simple to hook-up, first video is 7~8 meter/min , second one is 4m/min, before this set-up I have Mach3+smoothstepper, I either have rounding corner+smooth movement or square corner+jerky movement(stop at every curve"node") but can not have both, Kflop+kstep make my router run much smoother and no rounding corner at all,even at 8-10meter/min, and it is so stable,I like the way it run, slow down at corner before acc.
the system is so affordable, hardware and software,support are topnotch,
Thanks Tom for all your helps, a very satisfied customer.
IMG_0069.MOV - YouTube
IMG 0073 - YouTube
