586,728 active members*
3,397 visitors online*
    Jun 2009
    12
    fadal feed rate
    :boxing:run-a-way machine, no controll on feed rate, 20" ipm same as .001 ipm, feed rate same as rapid. NEED HELP, NEED HELP
    May 2004
    4519
    Same problem on all axis?
    Jun 2009
    12
    the feed problem seem to be in x & y axes only. Z axes feeds seem to be ok
    the mill is a fadal 4020, 1996
    May 2004
    4519
    The first test is probably to swap axis boards around and see if the problem follows the boards. If not, then the main board, eprom, or CPU is likely bad. Tech support at MAG (Fadal) was always helpful to me for talking through trouble shooting. You may want to call them.
  1. Feed rate
    By chris123 in forum Taig Mills / Lathes
    Last Post: 07-14-2010, 10:53 PM
  2. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  3. Feed rate for 5/8-18 tap
    By Eagle View in forum MetalWork Discussion
    Last Post: 09-24-2008, 03:25 PM
  4. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  5. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
