586,929 active members*
2,806 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > LOGOS TO GCODE THAT WORK WITH MACH3
Results 1 to 4 of 4
    Jan 2011
    51
    Iam trying to find a easy to use jpeg,bitmap or what ever to gcode that will work with Mach3 mill.I have been trying Image to Gcode,its easy to use and it make gcode but it wont run on my mill?I don't know computers all that well but I can get my mill to cut parts if I get good code.I had a few designs I wanted to cut on some lexan for edge-lit signs.I had a very nice guy create the gcode for me with vecteric vcarve and it ran great.I cant afford that software or know how to use it anyway.Are there any open source programs out there that will take say a logo and covert it to a Mach3 useable code?I dont need 3d or textures or anything fancy,just a profile and text cutting code.Any help would be great.Thanks Dave.
    Jan 2006
    2985
    G code is not rocket science, look at it and make sense of what the gcode says. Most likely you could easily tweak the gcode you are getting and it would run.
    Matt
    Apr 2012
    11
    Try lazycam? there's a few videos and a manual. It's Free I think.
    Read the mach3 manual pdf
    Oct 2009
    1
    logos
    hi
    if you have your logo in a dxf file then lazycam works fine and works with AND IN mach3
  1. image to gcode not work with redsail re1324 cnc
    By moh-alakoly in forum OpenSource Software
    Last Post: 04-08-2012, 04:21 PM
  2. image to gcode not work with redsail re1324 cnc
    By moh-alakoly in forum ArtCam Pro
    Last Post: 03-31-2012, 03:48 PM
  3. Why does my Gcode not work? Bobcad to Mach3
    By jrslick22 in forum Screen Layouts, Post Processors & Misc
    Last Post: 12-13-2010, 09:38 AM
  4. why does mach3 alter my gcode?
    By turbothis in forum Mach Software (ArtSoft software)
    Last Post: 10-17-2010, 11:08 PM
  5. Image to mach3 gcode
    By Woodenspoke in forum Mach Software (ArtSoft software)
    Last Post: 03-20-2010, 06:13 PM
