586,619 active members*
2,464 visitors online*
Thread: Surfcam help
Results 1 to 17 of 17
    Aug 2005
    21
    Surfcam help
    anyone here use surfcam
    Jan 2004
    539
    Oooh ya :cheers:
    Gary
    May 2005
    90
    surfcam
    sure do what ya need
    Aug 2005
    21
    iam having problems on running tool paths on trimmed nurb r surface i will attach part to see what you think
    Attached Files Attached Files
    May 2005
    90
    Do U Have The Surfcam File That You
    Have Already Tried To Run Toolpaths On
    I Would Like To See Exactly Which Surfaces You Are Wanting To Machine
    The Entire Part Or What
    Or Is The Software Just Giving You Errors
    Explain A Lil More
    Aug 2005
    21
    it seems like when i pick the surfaces to run the tool on it recognizes it but when you put in tool info it doesnt do anything the surfaces are in yellow running surfcam 2005 no errors are being given either
    May 2005
    90
    Are U Using Planar Machining Path To Try Those In Yellow
    Or What I Would Suggest A Tapered End Mill With That Radius On It
    To Machine That
    Let Me Show You How I Would Machine It
    I Will Post The File After While
    May 2005
    90
    here is the roughing pass i would use on this part
    but for finishing those walls i probably would get some tapered endmills to get the small radius in the corners along with the angle on the walls
    Aug 2005
    21
    scuba cant open file saying invalid version number im using 2005 build 120 no maintence
    May 2005
    90
    here try this one
    Aug 2005
    21
    how do i get that step reduction is it included in the 2005 ?
    May 2005
    90
    umm
    do what seat of surfcam do u have
    i have a 3-axis plus seat
    and yes it should be in 2005
    you can also use Z level roughing
    will work the same
    but with only one tool where are SRM will can use multiple tools
    Aug 2005
    21
    i have 3 axis plus 2005
    May 2005
    90
    Menu-nc-srm
    Is Where It Is On My 2005 Version
    They Moved It To 3 Axis On Velocity
    Aug 2005
    21
    ok i found it, you were saying to use tapered endmill for finish on the walls how would you get 2axis to recognize the geometry
    May 2005
    90
    creats splines along the top or bottom or the surfaces.
    i didn't examine your geometry to much
    but that is only goin to work is the taper walls keeps the same angle all the way around it
    if ya give me a lil time i can show what else i would do to finish it
    but im kinda busy at work this AM
    Aug 2005
    21
    ok i ll see what i can do with it i appreciate all the help
