How To Use CNC Wood Router To Create Frame
1. Create frame program in CAD software. Then output it to program edit software, in this software, you set toolpath, choose cutters for different job, such as engraving, drilling or cutting etc. Then output the program with the format CNC Wood router could read.
2. Put wood workpiece to cnc wood router working table. To make sure that wood work piece be clamped or absorbed tightly to working table.
3. Now turn on cnc wood router, move spindle to the position you want starting. And set home point.
4. Use dust collecting system for operator health, environment proteciton, machine protection.
5. When the cnc wood router complete its work, the spindle will move back to the homepoint. You can go on another work or turn off cnc wood router.
