586,266 active members*
4,314 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Newbie Question on voltage rating on stepper motors
    Mar 2010
    So I have a 24V / 15A 360W Dc regulated switching power supply coming & 5 Axis TB6560 that should be here tomorrow. I have 5 stepper motors. 4 sonceboz 1A/PH 9402 6500 R.416 and 1 STP-580116 2.0A/ 2.5V # 122546 ?? will these 5 motors work. or are the sonceboz to low power ? TB6560 says 1.5A - 3 A max. And the voltage rating is that the max 2.0A/2.5V ? or I am confused some motors have very low voltage on the labels and some have higher.. What is the deal with the low voltage numbers ? that the low end they will work ? top ?
    Thanks for any help
    Greg
    Mar 2010
    Soooo...... no help ?
    Jan 2010
    2141
    You do not need to be concerned about the low "nameplate voltage" of the motors.
    Your motor driver "chops" the power that it sends to the motors into pulses instead of sending a continuous voltage to the motors, and the driver actively limits the motor winding current to keep it at the proper level.
    Mar 2010
    thank you..
  1. Newbie Help on Stepper Motors
    By Trucks in forum DIY CNC Router Table Machines
    Last Post: 07-24-2009, 03:50 AM
  2. NEWBIE question Stepper Voltage Duration
    By albertsteptoe in forum CNC Machine Related Electronics
    Last Post: 12-05-2008, 12:11 PM
  3. help on stepper motor voltage rating
    By ravikhatri in forum Stepper Motors / Drives
    Last Post: 03-25-2008, 11:56 AM
  4. Stepper Motors and Voltage
    By stuart76 in forum Stepper Motors / Drives
    Last Post: 06-10-2007, 01:29 AM
  5. Replies: 8
    Last Post: 01-26-2005, 02:10 PM
