586,674 active members*
2,804 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > ISO 30, ER-16 tool holders?
Results 1 to 11 of 11
    Aug 2010
    101
    Does anyone know where I could find some ISO 30 ER-16 tool holders? My cnc router uses ISO 30 holders, and all I can seem to find is ER-32 holders for it--except for one from maritool which is likely too long to fit in my machine (ISO30 ER16-100 COLLET CHUCK TOOL HOLDER MariTool).
    Any help would be greatly appreciated.
    May 2004
    4519
    Aug 2010
    101
    thanks for the reply, but the Techniks site doesn't have any er-16 for ISO 30, and the Travers tool site is about the same length as the maritool one. I'd really like to find a short er-16 holder (like a gage length of 50mm would be perfect) because a longer one won't work properly in my tool changer. Granted, it's not entirely necessary to use it in the tool changer, but it'd certainly be ideal.
    Jan 2012
    This is a tough one to find (we don't carry it), however, ERI America (ERI America - Complete Supplier of CNC Rotary Toolholders and Accessories) seems to have one. The problem might be whether you need and ISO30 with 46mm diameter flange or an SK30 with 50mm diameter flange (everyone calls them ISO). They show one with a length of 60mm not 50 what you're desiring. What CNC machine is it for?
    Aug 2010
    101
    Quote Originally Posted by sfl2012 View Post
    It's a Pacer 2512K+ CNC Router (made by AXYZ) with an HSD spindle.
    Jan 2012
    ok you're running SK30 tool holders with the 50mm diameter flange. Check it out with ERI, it seems from their picture their flange is not smooth so this may damage your tool cradles...
    Aug 2010
    101
    So you're saying I should be looking for SK30 tool holders instead, even though the label on the spindle says ISO 30, and the parts catalog from AXYZ also says "ISO 30 cones"
    Jan 2012
    Technically yes... it's the flange diameter you have to be aware of. The SK30's are 50mm, the ISO30 are 46mm. This is the only major difference... I may have a solution for you but must confirm it.
    May 2004
    4519
    Quote Originally Posted by mafitch7479 View Post
    If you absolutely have to have this tool holder, it can be custom ordered. Try Techniks or Hardinge.
    Aug 2010
    101
    I just heard back from the tech at the router company, and it's for sure an ISO 30 taper. I might go with the maritool holder, but if anyone else has any ideas please let me know
    Jan 2012
    Just keep in mind that the HSD ISO30's run with a 50mm diameter flange (this makes them SK30 from a DIN standard point of view, it's only semantics...). Let us know how it works out.
  1. saving tool holders with the tool
    By Joesph Jackman in forum Mastercam
    Last Post: 03-19-2012, 12:19 AM
  2. CNC Tool Library (Creation of ISO 30 Tool Holders)
    By ender_wiggen in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-27-2012, 08:59 AM
  3. Cat 40 Tool holders
    By mwood3 in forum CNC Tooling
    Last Post: 09-16-2010, 02:58 AM
  4. tool holders?
    By gerald vern in forum Haas Mills
    Last Post: 08-17-2010, 02:17 AM
  5. GS Tool Holders?
    By leggetmachine in forum MetalWork Discussion
    Last Post: 11-01-2006, 04:12 AM
