586,636 active members*
2,935 visitors online*
    Aug 2011
    Mach3 vs LinuxCNC vs USBCNC vs CNCUSB
    Hello all,
    I' am planing my DIY CNC router i have everything well thought out besides the NC controller.
    Which NC Controller would be the best solution in terms of performance. I'am not technical oriented/or experienced to evaluate this 4 different solutions, maybe could somebody explain some pros/cons and general advise or experience using them.
    Best regards,
    Helder Costa
    Apr 2015
    27
    Re: Mach3 vs LinuxCNC vs USBCNC vs CNCUSB
    hey if your setting up a cnc router with ballscrews and stuff. to get you going, I would use GRBL with chillipeppr CNC controller. Providing you are comfortable with wiring, its by far the easiest to setup.
    The LinuxCNC and Mach3 stuff seems to take longer to get running and more days of configuring but offers more features.
    If its wood etc your routing then you couldnt go wrong with GRBL.
    Jan 2007
    599
    Since youre in his immediate area i would go with eding cnc, I have never looked at grbl, but from the little bit I just did seems like a great idea for a very small limited build.
    geluk ermee!
  1. g43 usbcnc
    By sapin in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-27-2014, 12:53 AM
  2. USBCNC CPU V4
    By Web Goblin in forum Controller Cards
    Last Post: 05-23-2012, 05:23 PM
  3. Setting up pwm signal for Spindle in Mach3 - copying setup from emc/linuxcnc.
    By craynerd in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2012, 08:00 AM
  4. Best purchase for my machine ever - CNCUSB
    By extonson in forum Fanuc
    Last Post: 08-31-2011, 03:44 AM
  5. postprocessor for USBCNC
    By Blerbaby in forum EdgeCam
    Last Post: 10-29-2009, 12:25 PM
