has anyone backed up parameters and programs from the 840d on to a flash drive via the front or behind the screen ports?
I would also like to know this
Message sent using the htc EVO with Tapatalk......2
I have done RS-232 communication on many Sinumerik Controls, but at one customer I find Error while opening the COM Port of CNC. There is no mistake in the procedure I follow. Is there anything in system which enables COM port of Sinumerik 840-D ?
There are 2 machines here, with same problem. As soon as I select a MPF file to send to PC, I get an Error on CNC as Job Terminated. If I see the log, it says Error in opening COM
Menu select
Servers
Data out
Select file to copy to flash drive
Disk/card
Tab to Arch format: Punch tape CR+LF
Start
Will copy to your flash drive.
Sent from my Nexus 7 using Tapatalk 2
Make sure it's same com port # on 840D as on the pc
WOW....that brings back memories. Always seem to forget that the Siemens control is just a PC. But we don't normally deal with com ports much anymore on the PC side. Most computers no longer even have a com port. But that reminds me I do have a com port to USB adapter that I could use on some of our older machines that do not have flash drive support.
Just come back couple days ago from Chiron America where we are passing off for new mails with 840D. Then by February we will have a total of 10 of them passed off. They are coming in for it a time. Hope they don't make changes in the control between each set.
