Novakon is excited to offer the spindle motor replacement kit for the NM-200 Series 2.
This kit is designed for our customers who wish to take advantage of the latest technology and to replace their BLDC motor/VFD set to the full capability of our new Torus Pro S3 CNC machine. It is our intention to provide a onetime bulk order to pass on volume savings to our customers wanting this upgrade.
Choice #1
Replacement of the BLDC motor/VFD set to the capability of the Torus Pro S3 AC spindle motor drive system. No controller upgrades required.
The kit contains the following:
1. 1500W AC motor
2. SunFar VFD
3. Motor mount plate
4. Motor pulley
5. Mounting bolts
6. Cables
Choice #2
Full retro fit of the controller cabinet to the configuration of the Torus Pro S3. The electrical cabinet will be upgraded to facilitate the new modular components on the high performance polyurethane chassis plates.
The kit contains all of the components in Choice #1 as well as the following:
1. Driver polyurethane chassis plate
2. Break out board (BOB)
3. Sinusoidal Stepper drivers (3) * Note 1
4. Power Supply polyurethane chassis plate
5. Terminal strip with relay assembly
6. 220 VAC power entry side plate
7. Interconnection cables
8. E-Stop switch
*Note 1: This represents the choice to implement a 4th axis driver option at an introductory kit inclusion of $185 USD with a savings of over 25%.
The added value for either choice of upgrade replacement kits is:
• High torque at all RPMs
• Value added of one year limited warranty (at no cost)
The polyurethane driver chassis plate will contain the servo driver, BOB, and up to a maximum of four sinusoidal stepper drivers. The power supply assembly is an all AC power distribution center for the AC components. There are no longer any DC driver components in the controller. The new E-stop switch will now control the Mach3 reset input as well as disable the AC power to the drive circuits. This will provide an extra safety margin by disrupting the power in an emergency situation.
A pictorial instruction sheet will be provided with each order, assisting the purchaser with assembly guidance. A moderate knowledge and experience in drilling and tapping new mounting holes will be required.
List Price: Choice #1 $995 USD or Choice #2 $2,395 USD
Special Price: Choice #1 $695 USD or Choice #2 $1,995 USD
Conditions:
This introductory offer is valid until May 25th, 2012. Orders will be specifically produced as per customer orders and will not be refundable due to the customized nature of the order. All orders will be accepted on a prepayment basis only. Kits will be shipped after July 25th, 2012. All shipping and handling costs will be the purchaser’s responsibility.
Warranty:
One year limited warranty.
This kit is not intended to affect the warranty of the original NM-200 Series 2 purchase.
We trust that this upgrade will enhance your machine and will provide future trouble free operation in order to facilitate future support issues. For more information please contact [email protected].
Novakon Team
