587,003 active members*
3,004 visitors online*
Thread: 3D TOOLPATH
Results 1 to 11 of 11
    Aug 2007
    422
    Question 3D TOOLPATH
    Hello,
    I am trying to get this part ready to cut and for some reason it is not working for me. I am limited in my 3d experience so it may be something simple. the files attached are for simple wheel. I have a 3/8" or a 1/4" ball mill to make the part. The part is 3/4" thick and I need it to be cut free at the end of the program. can someone help me get the toolpaths and code for this? I am using X3 and Mach3 on my Router (I don't have a lathe) if needed. Any help here would be appreciated.
    NOTE: the Mastercam file is attached as a .txt file, just rename the extension to .mcx and it should work.
    Attached Files Attached Files
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    May 2004
    4519
    What is the center hole size?
    May 2004
    4519
    I used Solids > Revolve and then save what you had as a STP file.
    Aug 2007
    422
    The center hole size was to be 1/8" but I will do that on a second opp. I can get it into a solid but the toolpaths/gcode is where I am getting hung up. Thanks!
    May 2004
    4519
    Go with 1/4" ball mill. Use Toolpath > Surface Finish > Contour
    Aug 2007
    422
    Quote Originally Posted by txcncman View Post
    I'll try that again with your file. it wasn't working right with my file. The verify looked really rough and didn't cut the part out at the end of the program.
    Aug 2007
    422
    Something is not right withthe way I am doing it. Anyone wanna take a shot at making the G-code for this with a 1/4" ballmill at .03" depth cuts? I can't believe I am having trouble with such a simple shape.
    May 2004
    4519
    Take a look at the MasterCam X3 file:
    Aug 2007
    422
    That looks like what I am trying to do except that it mills the od first and for some reason the center "hub" is getting milled out when there is no hole shown on the model. I am gonna play with it and see if I can get those figured out and see how you set it all up. Thanks for all the help so far.
    Aug 2007
    422
    I think I got it. Gonna call it a night and do a test run tomorrow after work.
    Thanks for the help! I'll let you know how it turns out.
    May 2004
    4519
    I did not set the center hole area as a drive surface. You can also select a starting point in the center.
  1. 3d toolpath ?
    By zewanil in forum Mastercam
    Last Post: 04-30-2012, 09:13 PM
  2. Help with toolpath.
    By MagooT in forum Mastercam
    Last Post: 02-20-2010, 02:04 AM
  3. toolpath
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 02-15-2010, 10:32 PM
  4. Toolpath
    By tomduyx in forum EdgeCam
    Last Post: 11-28-2009, 03:54 PM
  5. toolpath in mcx
    By craig in forum Mastercam
    Last Post: 06-01-2008, 08:58 AM
