586,469 active members*
2,860 visitors online*
    May 2012
    Fadal VMC 4020
    I need some help. I ave a fadal VMC 4020 milling machine and the z axis will not travel all te way down to the table. Its tops at 16.000 wen it is suppose to travel to 20.0000. How do i fix tis problem. I have tried everything I can think of, but i don't knowalot about the machine since i am new at it.
    May 2004
    4519
    Are you running the Cold Start procedure correctly? Tabs lining up? Has someone reset the machine zero position?
    Jan 2004
    3154
    Is your machine set as a 40 x 20 x 20 in the parameters?
    www.integratedmechanical.ca
    Sep 2009
    181
    Quote Originally Posted by reececup99 View Post
    It travels 16" down from normal home and 4" up for a total of 20"
    -Shelvin
    TheFadalParts.com
    [email protected]
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Apr 2005
    1194
    Quote Originally Posted by iess525 View Post
    -Shelvin
    How sad and true it is
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
  1. Fadal 4020
    By ghm195 in forum Fadal
    Last Post: 04-23-2012, 06:17 PM
  2. Fadal 4020 mm/um in MDI
    By hartan in forum Fadal
    Last Post: 12-20-2011, 10:50 AM
  3. Fadal 4020
    By joshuac in forum Fadal
    Last Post: 09-10-2010, 11:36 AM
  4. FADAL VMC 4020
    By dmac88 in forum Fadal
    Last Post: 05-18-2009, 08:45 PM
  5. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
