586,453 active members*
2,868 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 139 x motor z fault and occasional ground fault
    Jan 2007
    34
    1994 haas vf2 with new cable and x drive card and rebuilt motor in x. It has been giving me an occasional ground fault on tool change. It was worse until i unplugged and replugged the wires for toolchanger from the board. I was able to run at 50% rapid now I'm down to 25% or I get a 139 x motor z fault. Is there parameters that I should change? What are the parameters supposed to be set at. If some one has a list of parameters for the machine that I could get I would really appreciate it. Is there a good possibility that my main board is close to being shot? Need help desperately :drowning:
    Feb 2010
    1184
    Quote Originally Posted by duckslayer View Post
    The 139 alarm combined with the ability to run at a decreasing rapid rate indicates a faulty encoder.
    As to the ground fault, you can try blowing out the dust left behind by the brushes being worn down.
    Jan 2007
    34
    new encoder and turned up the screw on ground fault detector 1/4 turn. She's running better than ever and no smoke from the back box yet. Thanks for the help. one more question. How does an encoder lose track on rapids and not at lower speeds?
    Mar 2010
    1852
    The encoder uses rotating glass scales, read by a laser similar to a CD/DVD drive. So it gets dirty or the laser fails or gets weak are two ways. Most encoders now are 8000 lines or signals per single revolution, very delicate. So, slowing them down will help them out but not fix the problem.
    There are other things too like wires, but those are two main ones.
    Mike
    Feb 2010
    1184
    Quote Originally Posted by Machineit View Post
    Mike
    What he said!
  1. haas vf2b 1994 175 ground fault at tool change
    By duckslayer in forum Haas Mills
    Last Post: 04-25-2012, 02:18 PM
  2. Ground Fault Detected VF0
    By rkdygert in forum Haas Mills
    Last Post: 08-26-2011, 01:53 AM
  3. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
  4. 94 VF-0 17 Ground fault alarm
    By engine tech art in forum Haas Mills
    Last Post: 12-03-2010, 05:01 AM
  5. Ground fault error light on 1991 Partner 1D servo amps
    By Jim Shaper in forum Milltronics
    Last Post: 03-10-2010, 01:35 AM
