586,379 active members*
3,575 visitors online*
Results 1 to 19 of 19
    NEW NEMA23 Hybrid Stepper Motor 570 oz-in in stock
    We have 570 oz-in motor in stock
    NEMA 23 Frame, KL23H2100-35-4BM
    Can be used for G540, G251, G250 or any other drivers
    570 oz In. Hybrid Stepper Motor
    1.8° /200 Steps Per Rev.
    3.5 Amps Current ( Bipolar Parallel),
    4-wire, Bi-polar
    1/4" dual shaft
    http://www.automationtechnologiesinc...100-35-4BM.pdf
    Jan 2011
    91
    Re: NEW NEMA23 Hybrid Stepper Motor 570 oz-in in stock
    Does anyone have the specs for this stepper? Such as RPM, Torque etc...
    I'm trying to figure out how to gear it for a cnc plasma table.
    Dec 2005
    596
    What other specs do you need besides the ones he posted? Did you look at the pdf he provided a link to?
    Mark
    Jan 2011
    91
    Thumbs up Re: NEW NEMA23 Hybrid Stepper Motor 570 oz-in in stock
    Do you see RPM, Torque in that pdf? Nopt :nono:
    Here is more info for this motor. http://www.automationtechnologiesinc...100-50-4BT.pdf
    Probably a similar curve to the 5 amp motor, only the torque will fall off even faster. It's probably only good for maybe 350-400rpm max.
    Just a guess, though.
    Keep in mind that unless you use the exact same voltage, drives and microstep settings that are used for the chart, you may see very different results.
    Jan 2011
    91
    I'm going to try it with a 3:1 gearhead and see how it works.
    Dec 2005
    596
    Quote Originally Posted by modelaratrod View Post
    The torque is given both in the title and the body of the post. It's 570 oz-in. The only two things missing is the voltage and current "you" intend on using. Once you have that, you can use an online calculator to find out what kind of RPM's you're going to get out of the motor. For instance:
    Stepper Motor Calculator
    Jan 2011
    91
    Yes the "holding torque" of 570 oz-in, but I want torque while in motion as in the pdf I posted.
    Thanks for the stepper motor calc I'll check it out.
    Dec 2005
    596
    The torque is going to change over the range of RPM, depending on how much current and voltage you provide. Without knowing what you are going to provide, all the manufacturer can provide is a single torque curve based on the voltage and current they provide.
    That's why they provide holding torque, rather than torque in motion most times.
    Jan 2011
    91
    That makes sense. Looking @ the calc you linked to what's the "mH" on the imput "L" ?
    Inductance, which appears to be 6.4mH.
    Unless you keep the rpm under 300 or so, I don;t think this motor will work well with a 3:1 reduction.
    You'll be spinning it 3x faster, where it has 1/3 the torque.
    Jan 2011
    91
    Maybe this stepper would be better suited? http://www.automationtechnologiesinc...2100-50-8B.pdf
    It shows 2.7mH ?
    As for the gear reduction the gearhead is 3:1 and it will be turning a 14-1/2 Degree Spur Gear, 24 Pitch, 21 Teeth, .875" Pitch Diameter, 3/8" Bore so I'm not sure what the final reduction will be, is there a calculator for that?
    I can also run one these spur gears to find the sweet spot.
    teeth pitch dia bore
    21 .......... 0.8750..... 3/40....... 0.960.. 9/160 .... 3/80.... 6867K21, .... 47.85
    24 .......... 1.0000..... 7/80....... 1.080.. 5/80...... 3/80.... 6867K22....... 50.56
    36 .......... 1.5000..... 11/80....... 1.580.. 5/80...... 3/80.... 6867K23....... 58.48
    48 .......... 2.0000..... 11/40....... 2.080.. 5/80...... 3/80.... 6867K24....... 63.73
    Yes, but you'll need a drive capable of supplying 5 amps. The motor in this thread was designed to work with lower power drives.
    Jan 2011
    91
    I'm going to be using this drive. STR8 | Stepper Drives | Applied Motion It puts out 2.35 to 8 amps
    Jan 2011
    91
    I'm currently using applied motion drivers and have been 110% satisfied with there performance and support. I'm just looking to upgrade for more ipm to cut thinner steel.
    Jan 2011
    91
    There's also the fact that Applied Motion is "Made in the USA"!!! @ least it all was up until a few years ago.
    Attachment 265786
    Feb 2007
    17
    You can use around 80 volts max with that motor 6.4mh squared x32 = 80 volts
    Feb 2007
    17
    3 to 1 will give you 3 time the tork. for my self I am looking at the KL8070D to run the 570oz/in Motors with the 60 volt 20 amp unregulated power supply so if I want to up grade the motors to nema 34 later.
    So i don't have to buy new drivers later. You are building a plasma table and the gantry is the only thing that has to have a large motor on it. Nema 34 940oz/in or1200oz/in will run off the KL8070D so I would say it is more upgradeable than the KL5056D or KL8056D
  1. NEMA23 or NEMA34 closed loop stepper Motor System-Hybrid Servo kit
    By automationtechinc in forum News Announcements
    Last Post: 11-22-2012, 01:58 AM
  2. TB6560 board and NEMA23 stepper motor
    By helumad123 in forum DIY CNC Router Table Machines
    Last Post: 11-28-2011, 05:34 PM
