Bits Broken Reason Analysis on CNC Wood Router
CNC wood router bits broken reason can be devided to two kinds. One is engraving high hard material for long time. The bits get badly abrased and broken is unavoidable, if cnc wood router bits get abrased, then engraving depth can not up the requirement setted. After cnc wood router bits broken, we replace new cnc wood router bits, then how to ensure the same depth for these two bits? This is the issue we should consider. Here is the solution. When we find that the cnc wood router bits broken, stop the working, record the current position in the program. After the spindle stop, we replace new cnc wood router bits. It is because we reaplce bits by hand, this may cause different Z height, now we use tool sensor to calibrate the home point on Z direction. Then we get into advanced start menu, here it requires to input the position number. This number is the number we record it before. The number we input should be less than the number we record, and how much less will be depended on the time you find. Then you can go on the processing work on cnc wood router.
