586,129 active members*
3,115 visitors online*
    Oct 2011
    Replacement Microstep Driver
    Hi all,
    I recently had a rat in my Tormach 1100 that chewed a few wires, resulting in my Y axis driver blowing out. I fixed the wiring easily after killing the rat, but the Y axis was dead. I tried replacing the Y driver with the A driver, and everything works fine with the Y axis.
    My machine is serial number 1315. I ordered a new driver from Tormach, which arrived today. The new driver is Microstep Driver 30737 (for 4 digit serial numbers like mine). The old driver was Microstep Driver DS800. They seem to be identical from the specs on the outer case. I set the dipswitches to the same settings on the old driver. When I installed the new driver, the Y axis seems to want to go, but just sort of sits there and vibrates. I found the settings for the dip switches in the back of the manual, but still no go. Of course it is Friday night and Tormach is closed for the weekend.
    Any other ideas? Maybe I just got a bad driver.
    Thanks in advance for any help with this.
    Charlie
    Jun 2006
    3063
    This is one of those times when a phone call to Tormach will get you a quick answer.
    Mike
    Aug 2009
    986
    From the original post.
    Quote Originally Posted by cvant View Post
    Oct 2011
    Yep, called them first thing this morning and a new driver is on it's way. Thanks.
    Charlie
    Jun 2006
    3063
    Quote Originally Posted by TXFred View Post
    Ah, not quite sure how I missed that it was posted Friday night.
    Mike
  1. New microstep driver 6A
    By smartgsm in forum Open Source Controller Boards
    Last Post: 02-12-2011, 10:29 PM
  2. Building a microstep driver
    By izua in forum CNC Machine Related Electronics
    Last Post: 05-02-2008, 07:41 PM
  3. full->microstep driver
    By visky in forum CNC Machine Related Electronics
    Last Post: 10-28-2007, 04:26 PM
  4. The C11G with Microstep Driver 5056
    By newla in forum Machines running Mach Software
    Last Post: 02-05-2007, 03:46 PM
  5. My 3d microstep motor driver
    Last Post: 06-01-2006, 04:30 PM
